RUDEBOY
the nelson fai40 will go 40 flights with no problem, then you had better do a rodjob just for kick's. and when rob (mb) was in ft lauderdale him and bruce dechastel were talking about how bruces motor "the one he won the t/t with" has 200+ runs on it. also the globee plug is only for racing and the h/d nelson plug will go lot's of run before you need to change it.
there used to be a pylon event call quarter 15. find one of those puppy's and cowl in an fai motor and i think you will really scare the neighbors. RR
reason for edit
RUDEBOY do you like the specials.
