RE: Enya 1.20 question,,, Please help!
Marshall:
Your engine should have a paper gasket between the intake pipe and the cylinder head. In the earlier picture you posted I see no sign of the gasket. If it’s missing you could easily have a leak there. You can cut one from thin gasket material, or possibly a smear of silicone seal would do the job it the flange is flat where it bolts up.
Also, as you insert the pipe into the carb you should feel the o-ring in the carb body sliding on the pipe. If you don’t the o-ring there could be leaking as well.
Bill.
