Old 06-28-2006, 08:40 PM
PlaneKrazee
My Feedback: (14)
PlaneKrazee's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Enya 1.20 question,,, Please help!
Your engine cams are the same as my Enya 155. You have the larger R-120 not the small one and it is not timed the same. I believe it is like the copy Bill posted. I will get the timing info and scan it.
Your carb is a very special metering carb and the engine will run best with the low end richer than you would think it should be set. There should be a small black rubber seal around the needle, if not you can get one from MRC for about $.98.
You set the "bleed screw" half way open, start the engine, let it warm up, throttle up and set the high speed needle. Bring it down to a idle, set the low speed screw to give good transition abd raise the idle trim if required.
I always run a Enya #3 in a Enya four stroke.
If you are afraid of an air leak clean the parts with alcohol and use a tiny amount of high temp copper silicone to seal the joints. You can wipe a little silicone around the carb to intake pipe joint after it has been assembled.
PlaneKrazee is offline
