652 flaperon set-up
It isn't a bug, it is just the way the lower cost systems work, the 378 and up work a little different in that each channel adjusts individually. To increase travel you can either do it mechanically or increase the percentage in the dual rates. You can zero the flap channel travel to free up a mix, but using the mix works better for other functions.
