RE: Newb questions with Iwata and faskolor
The grainy texture is simply from it being water based paint. Your probably used to spraying solvent based paints, which are much smoother. As mentioned, since your spraying the inside the texture won't matter. It will look fine from the outside.
If your spray is still inconsistant, try reducing it even more.
