ORIGINAL: JDBlackhawk123
I've read many posts about the tail motors frying easily on the 22e and so did mine, after only 10 startups, with only the stock NIMH battery and no more crack-ups, crashes or other malfunctions (so far). This question may have been answered already in this forum, but I can't find it, so again is anyone using a better tail rotor motor for these things-I seem to remember someone posting about soldering a resistor in series in the voltage supply wire to drop the voltage, but I think this was only fro using lipos. Is there a brushless tail motor that can be popped in the 22e? I'm using the stock Walkera receiver and brushed motor for the main rotors-after changing the blade pitch and charging the NIMH through a few cycles it has plenty of power to get off the ground. Thanks.
try helihobby or rc and me also i think i saw some on hobbyestore also check out centuryheli...i seen it in one of them
