RCU Forums - View Single Post - Jr 8103 and DA100 trottle curve help
Old 07-16-2006, 10:55 PM
Airbike
Default RE: Jr 8103 and DA100 trottle curve help
Setup a mix using throttle as both master channel and slave channel, then adjust the values to get what you want.
Example, on Mix 2 (a multi point mix)
I set:
point L to 0, does not change the low point
point 1 to -4, decreases the mixed output so the throttle is actually a little lower than linear
point 2 to -7, adjust these middle three values until you get the response that you're looking for
point 3 to -10, ditto above
point H to 0 does not change full throttle point
I'm sure there are other ways to do it but this worked for me.
You can put this mix on a switch and turn it on and off in flight to see if you like it. Then maybe just set the mix to be on all the time to free up the switch for something else.
