Covering Advice?
Worldtex, Solartex & Colortex, to me seem all the same. You can put trim over it, with same material or have used Ultra-coat (Ora-cover) with good results. They say it is fuel proof, but oil in fuel will stain it (can`t remove it ). Needs to be coated with something to protect(clear Luster-coat , Perfect or a urethane). I have had very good luck with 21st Century fabric this is fuel proof with a doped fabric look, it also can be ironed one on top of another(no bubbles) In your case I would use 21st Century . Hope this helps. big max 1935 AMA 14958
