RCU Forums - View Single Post - jr 662 broken antenna tip
Old 07-18-2006, 08:08 PM
aus-voitty
Default jr 662 broken antenna tip
I have broken the tip off fy jr 662 and fixed it again. since then i have a new jr fm 610 reciever now i am having a lot of glithing problems and cant work out if it is the reciever or transmitter as i have flown succesfully since the repair was made using my jr 700fm reciever. was i just lucky or does the tip make a huge amount of difference, i lost about 1cm of the antenna at the first joint after the tip if that helps cheers.
