RE: Walkera 22e tail motor upgrade
The GWS setup-might be better for me (fewer parts to lose or break!) I had a hunch this might work. It certainly would avoid losing more tail rotor parts. I will install the GWS on 2 Walkeras if it works, I'll let you know-could replace the Walkera #4 and the 22e tail motors which by the way with this forum's help, I now have both airborne! It took alot to set up the 22e. The 22e CG is inherently tail-heavy-the true CG on mine without battery is just behind the main shaft. By putting the stock NIMH vertically instead of horizontally, it helped balance it better, but still needed some weight in the nose-that was my biggest problem! And better hardware in the head to replace broken linkages, but that is another thread, sorry. But man, can this baby fly when it's set up right-really nice. Thanks again much for the advice, I appreciate it.
