RE: How to troubleshoot an electric problem?
ahh yes i have the same plane when i first tried it wouldnt start either this is what i found out turn it on the full throttle it for about 15 seconds or until the red light on the esc starts flashing and then kill it then the throttle should work do this everytime when you turn it on oh and a tip of advice ... i am a vetran and i realized that this plane is UNDERPOWERED! it will fly good still just try not to do anything to big such as climb above 15 degrees. But good luck oh and if your taking off from the gras get rid of the tire cowlings. things get cought in them and you will nose dive it and unless you are taking off from concrete have somone hand launch it for you good luck
