Old 08-11-2006, 03:09 PM
  #2017
afpe45
afpe45's Avatar
Location: Rochdale , Manchester.Lancashire, UNITED KINGDOM
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: ParkZone P-51 Mustang RTF
@darnold,
when using rudder elevator (or in your case throttle) you use rudder and elevator(throttle) together but with a slight delay with the elevator(throttle) to do a turn, but you release the rudder(neutral) as soon as the turn in initiated, , So its rudder then elevator(throttle) then release rudder(neutral) and keep elevator(throttle) on enough to compleate the turn, as you slowly return elevator(throttle) to neutral the dihedral of the wing levels the plane out again, if you use rudder only you will spiral into the ground.
I hate rudder/elevator, give me elevator/Aileron any day. I only used rudder/elevator once and never again.
afpe45.
afpe45 is offline
