ORIGINAL: novielo
i did not removed anything of the original rx, all the plastic, plugs, and nicad are still there... i will balance everything and then i will remove all the excessive weight, balance again. it will be a part of my lerning to know the difference between, what's to heavy and what's ok...
micro says that you should have 1 inch of wing area for every gram of weight.
So a mere 25 sq. inch wing will carry 25 grams of aeroplane.
My planes come out heavy because I spare no glue in reinforcing everything.
They hold up better in a crash so it's less glue latter.
