RE: Nitro models pusher Bobcat?
I have calculated the cg several times using different websites, and formulas. They all come out about the same. Around 11" back from the leading edge of the wing AT THE CENTER OF THE FUSE or around 9.3 or so from the leading edge where it meets the fuse. This would agree with the few post back. However, this does not take into account the lifting design of the tail. But I am not sure that it would make all that much diff. However, I am going to get some measurments on a bvm bobcat wing and then run the numbers on it and see if it comes out where the formulas say. If so, then I will prob. try and bal. somewhere between the cg rec. and what I caculated.
any ideas on this?
