RE: Signal Interference
rimcnii, To small a gage wire between the battery and receiver can cause the problems stated; reason, it causes a voltage depression at the power input to the receiver due to IR drop in the wire. The receiver stops working for a few microseconds that the voltage is pulled down below threshold then, the servos stop drawing power, voltage recovers, receiver now sees signal again, servos now draw high current again causing voltage depression and receiver drop out---this continues and servoes appear to be glitching.
