RE: Signal Interference
Rodney,
Thanks for the explanation about the servo wire gauge. I use only 20 gauge wire for extensions. Also, use two battery packs for the gasser-Edge, both connected (through switches) directly to the receiver. Battery packs are 2700s with low (when used in parallel) internal resistance.
Perhaps the servo buffers are superfluous. I gather that you fly gassers (as does Dirtybird) and do not use more hardware than absolutely necessary (as does Dirtybird).
I sent my ignition module to RC Showcase for inspection. Apparently it was not functioning properly and must have been..at least intermittently..putting out a lot of noise. Have not yet checked the function of the receiver with the new ignition module. Hopefully that will take care of things.
I wonder what is going on with Flyinrain's receiver.
Anyone out there have any experience with FS8s in gasoline-engined airplanes????
Thanks again! rlmcnii
