Pro Bond and Vacuum Bagging
Thanks for the reply! As I am learning to use this sight, I am finding more on this subject. I have used saurgum in the past and didn't like it. Looks like Pro Bond and I will be good friends!
Do you usually use Pro Bond on your leading and trailing edge too, and bag it all at once or do you recommend using epoxy for these after the Pro Bond has cured?
