Where to buy pressure nipples
Thanks. I'll check there. The only ones I've seen are the standard size (although they have a small and large). The 5mm thread is quite a bit bigger than the normal sizes.
Hey Minn. Stay tuned. After the suggestions I've (or other people) received from you in the past about smoke systems, I'm putting smoke on this plane. I've already got the TME pump, and pre-heater in the Slimline. I have a couple of tanks, but I haven't decided on what size to use. Should be fun!
Mike
