RE: Nitro models pusher Bobcat?
Based on the current level of flight experience, what do you think about the 75 2 stroke that I am planning to put on mine. To much engine???
I have a .75 with an 11-8 three blade pusher prop.
I did add 1/4-20 nylon wing bolts, 15mm in front of the wing alignment rod. It seems to hold the wing on nicely. One thing I did that wish I hadn't is I CA'd the elevator into the horizontal stablizer based on the color pattren. When I installed the horizontal into the booms it turns out that the pattern was off center by a quarter of an inch. It still fits between the booms with clearance but it looks very rookie!
Bassman
