RE: Single servo glitch with engine running
Jim, what is left that you haven't replaced? If memory serves correctly, it is the battery and switch harness. Bypassing both those with a new battery and switch has to fix the problem. Just load them at the CG and you you should still be in good balance, even if slightly heaver.
One question on your replacing the servos. Did you replace them all at once, or one at a time??
By the way, did you check out the other forum thread I sent? The problem sounds a lot like yours.
I'm curious as to the trouble shooting with an AM radio, how does that work? It's the first I've heard of it.
Don
