All these ideas are good ones. I used a block of styrofoam, and trolling motor, and car battery. For the forward and reverse, I used an aluminum plate with the servo in the middle of two 12v momentary switches. Now I use a 51" deep vee hull I build with an electric motor and a motorcycle batt. I use regular gas hardware but convert it to take an electric motor. It is also easily switched to gas to "play". For the bait I attach a short pole to the boat, with a close pin glue to the top. A quick tug and it releases. Also with electric, you can tie your line to the boat with 2lb test. This way you can move it and fish at variable depths.
Email me for pics.
[email protected]
