RE: Super Stearman
Thanks for checking out the fleet of electrics. I only fly electrics as the town I live in has an electric field right by my house. I used the 5330 low count AXI on all of these but the Tri-Pacer. The Tri-pacer uses a 4130 and a 14.8, 4 cell and an 11.1 3 cell for power, and it swings an 18/12 E prop. The P-51, ME 109 run the same set up wiith the 5330 low count on 2, 14.8 4 cell packs, The ME 109 uses 8ooo mah not the 6000 like the others. The Boeing F42B uses the same power system, 5330 low count and same 6000 mah packs as the P-51 but I am using an 22/8 wood prop to get some wind over the tail and wings. I had a 18/12 on it but not enough wind was reaching the flying serfaces and it was not fun on the ground and slow to get off the ground. The amps stayed the same at about 54,
The pitts is going to have the 5330 F3a in it with 9 cells. Maybe 3 packs of 11.1 8000 mah packs???? I need some prop clearance on the Pitts too.
