RE: Slow Stick Component Help
the motor is a brushed motor...... I have a ss with the same motor.. and it seems fine to me... if you are new to electric flight... I wouldnt worry about getting a brushless motor and anything too fancy until you are a good pilot... cause it dont matter what bells and whistles you put on the plane if you cant keep it up in the air.....
but your setup depends on if you want to go with a lithium battery setup or a regular battery .... if you go with lithium.... you will need a electronic speed control designed for lithium battery.... There are recommended flight packs on gws.com/tw
