ORIGINAL: NightHawk18
Yeah i was worried about that so if you look at my blurry pics then you can see i mounted it like in three places so it wont bounce around. It has actually lowerd my engine temp about 15 degrees or maybe its because i waswnt running very hard.
Today though, i started my car and went to start driving and i thought man i stripped my gear, but then i noticed hmm its still running smooth. So i took off and i saw what the problem was, the car is running only front wheel drive, the two front are spinning but the backs are free rolling, this also makes my brakes not work for some reason. So my question is is it something stripped in the back or is it just something i have to tighten or push up, i dont hear anything rattleing in the back gear area so idk.
thanks for all the info Jared
Jared, check the grub screws circled in yellow on this picture:
http://image.rcuniverse.com/forum/up...49/Ed61448.jpg
Picture is from a tutorial on rebuilding your trans written by Chubbysuncle here:
http://www.rcuniverse.com/forum/m_42..._8/key_/tm.htm
See post #184
Mark[sm=48_48.gif]
