Engine mounting
Hello
I'm ready to mount the engine on my CG Tiger 2. What is the proper procedure for aquiring the proper angles. (IE: Right thrust and Down thrust) How are the degrees measured? Is it all that critical? I don't think the kit manufacturer would set these specs. if it wasn't. Some people say they shim the engine mounts. Is this a proper tecnique? Thanks for your input.
