RE: saito 100 wont idle
cbr954rr.... The spray bar is lightly pressed in... If you pull it be very careful, or you will
need to get a new one.... I just changed my bearings on my 100 to ceramics, and I had
to get a new spray bar, "because I wanted to clean it out good"..... Check out the engine
section... Club Saito.... All the info./help you will need
I would also insure that your low end is rich enough, Saito IMO likes to be a tad on the
rich side on the low end
