RE: Does any one have thunder tiger experience with thunder tiger ek4-s2 pro 70 motor
Shocks will go out first and then the wheel bearings and diffs. After running your EK-4 inspect everything as this truck goes really fast and wheel bearings don't last. Parts are available from ACE through a dealer and they are no more expensive that others the truck just goes so fast and parts don't last. You can think of you MGT with three engines and that is about how much power the TT 70 makes. Run it rich and break it in right and it will give you good service. I replaced the heat sink with the larger factoy one and it really runs cool. Have a ball! wo
