ORIGINAL: gsmith6879
I have not decided what to use for power. I don't think the .48s will handle the real weight of the C130 so I am looking at MVVS .61 with the same setup or RCV .61-SP 4 stroke (
http://www.rcvengines.com/rcv60sp.htm). The RCV will fit very well inside the cowl and will let you swing a scale size 4 blade prop. I need to look at sizing and cooling before making a decision.
I've deceided to go with the RCV 90's for power. I'm having custom made 4 blade props made up for the Herc. The RCV's fit perfectly inside the cowl with only the carb sticking out. The exhaust will be run out through the rear as in the full scale. The props are still being made up. I wanted that wow factor when you walked up to the Herc. Also i did not want to switch from static props to flying props. The RCV 90 has a stump pulling amount of torque.
Grinder.
