setting crow mix?
To do this, you would have to set up a separate program mix, as the pre-set up mixes for elevator to flap and aileron to flap only give you the choice of the mix switch or the flap switch. You could just move one of the mixes to a program mix, for instance do a mix aileron to flap, assign it to the switch of your choice in the mix, and set the rate as needed.
