ORIGINAL: UkerDuker
Grinder-
You mentioned installing RCV 90SP's. THat would be a great engine for this project, but you will have to move your firewall back. WIll the props have sufficient clearance? WIll these engines interfere with the installation of the fuel tank? I think this is the only real challenge with this aircraft. Everything else seems to be relatively straight forward, except on a much larger scale.
Mike
Yes the firewall would have to be moved some. I can't think off the top of my head exactly how far but it's do'able. I think 15.75" was the largest you could go for props and miss the fuselage. But they will be cut down to 13" for scale looks. Early on realizing the firewall issue my thoughts were to have one main tank at the CG and four fuel lines one for each engine. But i think i will just go with the smaller tanks in each nacelle.
Grinder.
