retract servo suggestion needed
Hi folks,
I need a servo to actuate two mechanical retracts. Last time I did this, a standard (futaba s148) wasn't quite strong enough so a bought a hi-tec retract servo only to find out that it would only move thru 180 degrees, in that case I did a 'genetic' modification by connecting the mechanism to the s148 electrics and got it proportional, however, I don't really want to do that again.
So what can you suggest that is not a fixed 180 degree movement and cheap'ish? Size wise it should be as per a standard S148.
Cheers,
Chris
