RE: E-Flite Mini Pulse XT Owner's Club
I also ran into the same problems with the spinner. You can't tighten down the prop nut without deforming the spinner, and then the cap does not fit on right. So I am going without for now. I am going to try and get a Dubro, but even still the prop adapter does not appear to be long enough for the spinner. It just does not have enough thread left for the prop nut. So I will probably have to order a new prop adapter if I go that route. At the same time I was thinking about cooling the motor. The spinner blocks the hole in the cowl completely. So the only air intake to cool the motor, ESC and battery are the side vents, which basically bypass the motor. So it may be better just to do without the spinner.
