RE: Spektrum DX-7
I'm not all that sharp on the technical issues involved with the SS equipment.But,I think SPEKTRUM has to be pulling BOSSHOSS's leg when they state " there is problem taking the PPM modulation and converting it to "perfect time" as their reason for not pursueing a "Module" based implementation.
If ," there is problem taking the PPM modulation and converting it to "perfect time",the people transplanting the RF section of the DX6 into 72mhz JR radios would be encountering the problems.From what I have been led to undrestand,putting the DX6's rf board into whichever JP transmitter appears to be the DX6's twin,works perfectly.The practice has also been given the green light by the AMA.
Apparently 2.4ghz equipment isn't governed by the regulations of the "Personal Radio Service",as our 72mhz systems are.And the regulations against using a "Hitec" module in a "Futaba" radio(for example) don't apply.
