RE: HELP! Engine Mounting Problem!
Hi,
The blind nuts are fine. I take it you are building a kit? Usually the locations are pre punched. Just drill the holes and then epoxy in the blind nuts before glueing in firewall. Make sure you use epoxy for the firewall and some triangular stick on the sides for added securing.
I think I misread your original post re the bolts. I meant to use the nylock nuts for securing the engine to the mount. The blind nuts are the norm for securing the mount to the firewall.
Regards
Mark
