RE: pink foam ribs and koverall
I use behr water based satin poly to attach Koverall all the time. Make a small sample with your ribs in a frame and experiment to perfect a system. I go over the outside perimeter with a medium heat iron after the poly is dry to ensure a proper seal then shrink covering before doing the ribs.
