RE: Need help balancing Edge 540T!!! What do these symptoms indicate?
One thing that no one has asked is.......:
Have you checked your thrust? Have you done a thrust line?
On my 80" Yak I kept thinking it was too noseheavy when the CG was near tailheavy. Turned out that I had to add a little up thrust to the firewall (rebuilt before) to get it to trim out. Now it's a dream to fly with no input upright or inverted. This also caused it to land pretty hot since the thrust was pointing down when upright. Just something to check on.
