RCU Forums - View Single Post - Funtana S90 ARF Question(s)
Old 11-04-2006, 12:48 AM
KidVermin
Default RE: Funtana S90 ARF Question(s)
I brought the antenna out the bottom of fuse below Rx and taped along underside .
Mine hasn't shown any sign of interference by letting them dangle.
The 90 does have a weak landing gear. I drilled a hole midway up each side and made a torsion rod from a 12" 2-56 rod. Bend one end in a J shape with enough of the threaded end coming out the other half of the gear, then a washer and 2-56 nut to keep the gear from spreading apart on a hard landing.
