RE: Valve adjustments on 4 stroke motors
Hi can anyone tell me the correct method of setting the valve timing on a super custom 91 ? also has anyone had the gears on the crankshaft and the gears on the cam shaft jump damaging the gears and upsetting the vave timing, is this a common problem? Thanks briands.
