Using Hitec RX with Futaba and JR TX
With JR/Airtronics you must either use a shift select RX or a dedicated RX. Same for Futaba/HiTec. If your using either type TX's [negative/positive shift] it makes sense to purchase a shift select RX.
Its important to realize you must use a HiTec crystal with the HiTec RX's. HiTec RX's will accept any range of crystal hi or low band...
HiTec RX's have been tested by many RC Tech Guru's all of them give Hitec a thumb's up... Threre actually far superior to much of the OEM stuff that is floating around from years gone by...
