RE: 6102 sMix Setup
That is all fine and I managed to do the setup and I do understand that. However when I get to the section saying "Mixing Elevator to Flap" that is where
my problem starts. According to the Ultra stick manual they clearly show that "Mixing Elevator to Flap" is where the Flaps (inside 2 ailerons) go down
and the elevator go up and that will ensure that you can do tight loops. My radio the x2610 (same as XP6102) only have the following under the
ELEV - F Mix = E-DN = %
E-UP = %
SW - secting which switch to use for this feature
this is on page 36 of the manual.
When I apply the feature with the spesified switch the ailerons(outside 2) go down and the elevator go up.
Jan
