RE: Air Hogs Aero Ace!
Good Luck DJ, I'm at a standstill on my monojet.
I just pulled out my last bipe, the one that would only turn in circles despite equal readings on the tach. AA 101, if the plane only turns in circles check motor direction first. I forgot that part. I forgot how much lift the plane has as well, I was flying in a wierd wind condition and the plane would hang in place and then slowly move forward as the wind changed direction, in about a minute or less. After determining that the thrust angle was my problem I brought that plane in and tried another. The single stir stick was extra twitchy, but flyable. I'm looking forward to the next time I can bring out the planes and try out a bipe all over again. I'm also considering pulling out an unmodded controller. As I remember with the un-modded controller you can feed in as much or little throttle to the turn. Tim
