RE: Air Hogs Aero Ace!
micro, I started on the AA version of the flying wing last night but
I'm debating on what the wingspan should be.
What size would you build? Even a small plane will have lots of wing area.
I've gotten a test piece done and I'm using a stunt style airfoil sandwiched
between two 1.13mm foam plates. I've finally found a good way to join
foam sections together and a way to make decent prop slots.
The center fuse will be a 1.80mm bottom with the top piece of 1.13mm
added last.
All wing sheet should make it weigh easily under 10 grams.
