Old 01-25-2003, 06:50 PM
hebertjj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Preferred linkage for thottle?
What I've done on my last few sport planes was just a piece of small, flexible, music wire with an "L" bend on the throtle end and straight on the other going into an EZ connector on the servo arm. Angle the throttle rod guide rod out of the fire wall so you get a little offset from straight line to the throttle arm. Bend the MW to stick the L into the throttle arm and the slight side tension on the MW will keep it there. Makes removing MW and/or engine a lot easier than a Z bend and it's simpler than a ball or clevis.
Clear as mud?
Joel
hebertjj is offline
