RE: 40% GILES WITH A 120 ?
Yea, I guess changing technique could help.. We land on about 400ft With and about 5 ft trees on either end.. So my area is really around 325 or so........Setting down is not bad but the roll out can be a problem.... I've had my transmitter adjusted so that at my slowest idle if I put pressure on the bottomed out stick the idle will go to a tick and slow IMMEDIATELY. Now , you can't adjust the idle on the trim to that "tick" mode Even when you have the trim adjusted to ts highest resolution from the radio... I'm rethinking the short trottle ny-rod ( 3 inches) to see if that might help resolution.
Once I get the gear back in, I might give a tank to touch and goes and see if I can get my landing pic adjusted...
SO will the 260 wings fit the GILES ?
