RE: Magnum Look A LIKE!!!
Yes seperate pushrods for the elevator. uses the same exact setup as the magnum. uses the plastic plate as a joiner.
The weston 50 fits like a glove. Same exact engine bay.
Airfoil is identical also. thicker plywood on the sides of the fuse. not at flimsy as the magnum.
