I tried the method you suggested. It definately helped. I also used the PANE, then PPAR command to reduce the number of nodes, which speeded up computation and also helped get rid of little imperfections.
I've attached an image of the latest results. Much, much better!!!
Thanks again. You have been a great help!!!
-Q.
Originally posted by drela
Try this...
LOAD airfoil_filename
MDES
FILT
! (repeats the previous FILT command)
EXEC
<Return>
PANE
SAVE smoothed_airfoil_filename
Type "!" as often as needed to smooth the airfoil sufficiently. Looks like yours will need at least 10 repeats.
