Hobbico Electristar Select EP Trainer RTF
Performance meets convenience when a traditional .40-sized trainer is redesigned to use today's advanced electric flight technology. The all-new Hobbico [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXNVC0**&P=ML]ElectriStar Select[/link] uses clean and quiet electric power, making it economical to operate and ready to fly in under an hour! Unlike other smaller or underpowered electric trainers, the ElectriStar Select flies just like a .40-sized glow-powered trainer! The ElectriStar Select was engineered from the ground up as an electric-powered plane, so unneeded weight could be removed from the airframe without compromising structural integrity. The factory-installed, high-performance ElectriStar C-42 brushless out-runner motor provides the performance you would expect from a conventional .40-size glow engine. The ElectriStar is stable, strong, and with a wingspan of more than five feet, it's easy to see in the air!
Specifications:[ul][*] Wingspan: 63 in (1600 mm)[*] Wing Area: 709 sq in (45.7 dm2)[*] Weight: 6-6.5 lb (2720-2950 g)[*] Wing Loading: 19-21 oz/ft2 (59-64 g/dm2)[*] Length: 53 in (1345 mm)
[/ul]Features:[ul][*] With the computer radio and brushless motor already installed, final assembly takes less than an hour![*] The two-piece wing slides onto a strong aluminum joiner tube, to speed assembly.[*] A bolt-on tail makes the ElectriStar Select quick to assemble, yet is easy to remove and replace if required.[*] Includes: Futaba® 4EXA 4-channel computer radio w/R168 receiver and 3 servos, 42 mm brushless out-runner motor, Great Planes® ElectriFly 45A brushless ESC
[/ul]
