RE: DDM 30.5cc kit question
Did you install a new carb gasket ? make sure the vaccum holes arent plugged up with any sealant or anything . you resest the needles you said ?might need to turn up your idle as well that wontr hurt anything till you get it running because once you richen out your needles the idle drops right down and might be closed ..?..
Good luck
