Bob,
Yes the CG location 4 the tank is due to size restriction up front (retracts) so i'm not sure even the "round" 8 oz would fit in there[
so i was going for the 12 on the CG...
What sizes do you recommend?
Would a 4 oz standard (fitted up front) combined with a 8oz on CG do the job ?
In a parallel setup, would the the 4oz empty as well or stay full as in a hopper setup?
The purpose of the backplate mount was to eliminate the "engine mount in the pointy nose problem", but i just might put a 2" spinner & sand the nose-cone to the larger dia. Would Dub's 2" spinner look right on the Patriot? if not which one of Dub's spinners would look the best...?
Last question, Dub's alum engine mounts come pre-tapped right? would it fit in the P. nose? if yes, i'm getting one
Thanks for the advice,
V.
