RE: *** CLUB SUPER TIGRE ***
I'm not really up to date on the latest ST carbs so I have to ask when the design was changed to make them into a bad carb. I've only got 2 RC ST's, one is an ABC GS45 that I got second hand and it runs flawlessly. The other is an unrun 80's ringed G45 (with the earlier round head) and with an external needle for the idle mix. I nicked that carb to use on an OS61VF but took out the venturi restrictor to get the same area as the original carb. It was dead easy to set the high and low mixtures and it gave the fastest and cleanest transition I've ever seen. So, no complaints whatsoever with either of those carbs which leads me to think they must have been changed at some point.
